21 years agolwip MicroC/OS-II throughput
Does anyone know if the throughput rates on pate 1-31 of the "Using Lightweight IO with the Nios II Processor tutorial" document was for 100Mbps ethernet? The transmit rate of 5.16 Mbps seems r...
20 years agoHeavenscape,
on this forum (I believe) there is a stand-alone version in the IP-section. A manual can be downloaded from somewhere on the internet. Just try to google it http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif . I reached up to 80 MBit/s with this stack http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif ... Therefore I clocked the Stratix II FPGA to 135 MHz... Used a lot of datacache and instruction cache.... Good luck with it!!! Cheers, Danny
