21 years agolwip MicroC/OS-II throughput
Does anyone know if the throughput rates on pate 1-31 of the "Using Lightweight IO with the Nios II Processor tutorial" document was for 100Mbps ethernet? The transmit rate of 5.16 Mbps seems r...
20 years agoHi DannyJacobs,
Thank you for your attention and suggestion!! I am not quite sure how to use the lwip stand alone version. Do I just need to copy the relative source files into my NiosII project and rebuild it? When I call a lwip stack function, how can I know if it is the stand alone version is called or it is the version provided by NiosII kit is called? Or is there a tutorial or example that shows me how to use the stand alone version of the stack? Thank you!! Regards, Heavenscape --- Quote Start --- originally posted by dannyjacobs@Aug 21 2006, 01:58 AM hi heavenscape,
you should be using the lwip stand-alone version if possible. that way you can reach the highest bandwith http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif
cheers,
danny
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17737)
--- quote end ---
--- Quote End ---
