21 years agolwip MicroC/OS-II throughput
Does anyone know if the throughput rates on pate 1-31 of the "Using Lightweight IO with the Nios II Processor tutorial" document was for 100Mbps ethernet? The transmit rate of 5.16 Mbps seems r...
20 years agoHi all,
my testing environment is Cyclone 1c20 chip, 50MHz Nios II cpu, Lan91c111 MAC. I am using lwIP 1.1 with Quartus II 6.0 and Nios IDE 6.0 software. I am transfering bulk image data from the embedded system to PC via UDP and the fastest speed I ever got is about 9Mbit/s ( 1.1MByte/s). The problem is that when I use any compiler optimize options when building my NiosII project, it stops functioning. It must be compiled with -O0 level. Does anybody have any idea about this problem? Thanks!!
