21 years agolwip MicroC/OS-II throughput
Does anyone know if the throughput rates on pate 1-31 of the "Using Lightweight IO with the Nios II Processor tutorial" document was for 100Mbps ethernet? The transmit rate of 5.16 Mbps seems r...
20 years agoHi Soin
you wrote about a UDP-server implementation with MicroC/OS-II. Could you send me an example of your way to send UDP-packages? I'm trying to do without it, but so far it doesn't work. When I send something it always goes from source port 0 to destination port 0. Cheers, Danny
