21 years agolwip MicroC/OS-II throughput
Does anyone know if the throughput rates on pate 1-31 of the "Using Lightweight IO with the Nios II Processor tutorial" document was for 100Mbps ethernet? The transmit rate of 5.16 Mbps seems r...
21 years agoWhen using LWIP + uCOS, I see there are quite a few tuning options available thru the GUI and in the file opt.h . What changes to these default options are you finding helps the performance? Is there better documentation (other than the code) to explain what some of these do?
I see that some are using a 10ms timer interval for uCos, despite using a fast clock. I believe the HW timer defaults to 1ms, so was there any performance testing done as a reason for the longer interval? thanks
