21 years agolwip MicroC/OS-II throughput
Does anyone know if the throughput rates on pate 1-31 of the "Using Lightweight IO with the Nios II Processor tutorial" document was for 100Mbps ethernet? The transmit rate of 5.16 Mbps seems r...
21 years agoHi,
i've finished my LWIP uCOSii UDP test today and i have reached these results: UDP TX 35.55 Mbit/s (UDP payload rate,packet length 1472 byte) UDP RX 17.66 Mbit/s (UDP payload rate,packet length 1472 byte) I've used a Stratix 1S10 development board with a NiosII(f) 100 MHz clock. If you are interested, i can tell you more. bye
