20 years ago
LWIP broadcast
I have set up NIOS w/LWIP as UDP client. Addresses are fixed, not using DHCP. I can send and receive okay to fixed IP addresses, but LWIP will not receive a packet when the server sets the last dot quad to .255 instead of the particular value (.003 in my case). The subnet mask both server (a PC running Labview) and the client (NIOS) are 255.255.255.0. Packet sniffer shows proper packets.
I can trace (by breakpoints) the UDP packet with x.x.x.255 address to the function udp_input (in file udp.c), but the function does not recognize the packet as being of interest and doesn't process it completely, so the function recvfrom() never returns. I can't tell exactly what is going on within the function, but I'm pretty sure this is where the hangup is.
Has anyone had any luck receiving broadcast UDP packets? Suggestions?
Thanks for your help,
Tim
    I have developed my own patch that appears to solve the problem. In file udp.c, line 216, replace
    ip_addr_cmp(&(pcb->local_ip), &(iphdr->dest)))) {
    with
    ip_addr_cmp(&(pcb->local_ip), &(iphdr->dest))) ||
    ip_addr_isbroadcast(&iphdr->dest, inp) ) {
    effectively adding a check for broadcast to one of the many checks of the packet control block. I am not sure this is rigorously correct, but appears to work. Comments invited.
    Tim
    Hi Tim,
    I've question regarding your patch.
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    ...p_addr_isbroadcast(&iphdr->dest, inp)..[/b]
    --- Quote End ---
    What kind of type is the variable inp? Because i cannot find a variable in the code that is suitable for that.
    Peter
    EDIT: OK found it by myself :-)
    I have simular issue. I have setup the NIOS udp client but when a broadcast message is sent out on the network my receive led flashes but my break point in the udp.c file does not get hit. If I send a regular udp message it does? Whats that all about..
    mask = 0xFFFFFF00
    IP = 192.168.31.44
    PC is broadcasting SO_BROADCAST out
    mask 0xFFFFFF00
    IP = 192.168.31.45
    Used 192.168.31.45 to send out broadcast..
    Used 239.0.0.31 to send out broadcast.. above NIOS gets neithe but will receive
    a regular udp message to it.
    Dear friend,
    I am trying to communicate through UDP from nios-ii to my PC ...please send me a sample code. as the one i had write generate lot's of error related to header files.
    kaushal
    --- Quote Start ---
    with
    Tim
    --- Quote End ---
    Tim, please join the lwip-users mailing list and submit the problem and your proposed solution. Development on lwIP is active as a new major upgrade is in the works. You didn't mention lwIP version and you'll need to do this there. Here would have been nice too. :)
    https://savannah.nongnu.org/mail/?group=lwip
    Bill
    Hello all,
    I read discussion about broadcast listening, but i need to send broadcast from nios to network, could you advise me:
    I include code:
    void udp_init_all(void)
    // proved nastaveni ciloveho adresata soketoveho spojeni
    host = gethostbyname("192.168.3.255");
    if(host==NULL)
    { printf("Address error.");
    return;
    // nastav struktury a cilovy port adresata
    remoteServAddr.sin_family = host->h_addrtype;
    memcpy((char *) &remoteServAddr.sin_addr.s_addr, host->h_addr_list[0], host->h_length);
    // remoteServAddr.sin_port = htons(serverPort);
    // navaz sitove spojeni
    if ((socketDescriptor = socket(AF_INET, SOCK_DGRAM, 0)) < 0)
    { printf("Not able to create socket connection. \n");
    return;
    // exit(1);
    serverAddress.sin_family = AF_INET;
    serverAddress.sin_addr.s_addr = inet_addr(SRC_IP_ADR); //"192.168.3.238");
    and sending code:
    // nastav adresu portu a posli udp paket
    if (sendto(socketDescriptor, out_buf, len, 0,
    (struct sockaddr *) &remoteServAddr, sizeof(remoteServAddr)) < 0)
    { printf("I am not able to send data to remote server.\n");
    // close(socketDescriptor);
    return;
    // exit(1);
    and sending code report me:
    What should I change ? Where is error ?
    Jan Naceradsky, Altera
