21 years agolwip 10Mbps
I am using the Cyclone Development board with uC/OS-II running LWIP and seeing many lost packets, Dup ack, and Out-Of-Order packets with TCP. I see all of the above issues when using 10Mbps hub...
21 years agoThere were two previous bugs found in the lan91c111 drivers:
http://www.niosforum.com/forum/index.php?a...&f=17&t=619&hl= (http://www.niosforum.com/forum/index.php?act=st&f=17&t=619&hl=) http://www.niosforum.com/forum/index.php?a...&f=17&t=703&hl= (http://www.niosforum.com/forum/index.php?act=st&f=17&t=703&hl=) I believe the first bug fix was incorportated into Nios1.1, but the second was not, and could be related to what you are seeing. If you fix it, post your solution.
