VRama10
7 years agoLVDS error in 18.1 while using Triple Speed Ethernet IP
Hi, I'm a beginner with Nios II platform designer. I was using an example project from Intel built for Cyclone 10 GX board using Quartus 17.1. It was working fine. As I need to integrate this des...
SreekumarR_G_Intel
6 years agoHello , sorry for very late reply
Would it possible to find the revision of the eval board and cross verify ?
Each Rev there will be different pin out and changes in the schematic design as well.
Thank you ,
Sree
YHäri
6 years agoWe also have the same revision: 100-0321329-A1 Rev A.
Best Regards
