21 years agoLost SDRAM controller
Hey what's up. I installed SP2 and lost support for the SDRAM controller. What's a fellow to do. www.altera.com was no help. Perhaps it's time to switch FPGA supplier...
21 years agoFirst, it is important to know if you were using the "legacy" SDRAM controller or the new one. The class-names are altera_avalon_sdram_controller and altera_avalon_new_sdram_controller, respectively. Opening your system PTF in a text-editor is the most definitive way to check this; you may be able to tell by the GUI but I'm not sure offhand.
Then knowing whether or not you are using a Nios-classic or Nios II will be needed next. The Nios-classic ships with both SDRAM controllers, but Nios II only ships with the new one. If you have recently switched from Nios-classic to Nios II and have a design with the legacy controller, but have removed your Nios-classic kit, then you will find that the component will show up as "NOT INSTALLED". If you didn't remove the Nios-classic, then it's possible that it got lost from the SOPC Builder component path (check $SOPC_BUILDER_PATH on your system). You can find out what SDRAM controllers are on your system by searching for the files em_new_sdram_controller.pl (for the new one) and em_sdram_controller.pl (the legacy one). You can also check the "install.ptf" file in a subdirectory called ".sopc_builder" under your home directory. Please let us know what you find along these lines, and fill-in any other relevant details. I'm sure we can resolve this for you. As for the original suspicions: the SDRAM controller is shipped with Nios, and not with Quartus/SOPC Builder, and the Quartus 4.1 SP2 installer will not delete your SDRAM controller.
