20 years ago
Long division on Nios 2
Hi there
I have a question:
Has anybody performed "long division" on Nios-2? I mean 64-bit/64-bit signed
and unsigned division with [unsigned] long long of [unsigned] long data types
(depends on the compiler). In GCC terminology, this should be an UDW/DW data type.
I mean has anybody verified that "libgcc2.c" compiles OK for Nios-2 regarding
the following runtimes: "divdi3", "udivdi3", "moddi3", "umoddi3". These ones
call "divmoddi4" for performing the underlying arithmetic, so this
question applies to "divmoddi4" as well.
Kind regards
Nikolaos Kavvadias
    Yoo-hoo!
    does ANY 64-bit operation work on Nios-2? I mean there are no "movdi" (for DItype) patterns, right?
    I just want to know what should have happened when compiling s'thing like:
    unsigned long long a = 0xAAAAAAAAAAAAAAAA;
    unsigned long long b = 0x5555555555555555;
    unsigned long long c;
    c = a/b;
    kind regards
    Nikolaos Kavvadias
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    I just want to know what should have happened when compiling s&#39;thing like:
    c = a/b;[/b]
    --- Quote End ---
    I can say that the division should work. I did already before. But I think if you want to specify the constants, you need to add LL :
    unsigned long long a = 0x1122334455667788LL;
    Stefaan
    --- Quote Start ---
    originally posted by svhb@Oct 19 2006, 12:39 PM
    i can say that the division should work. i did already before. but i think if you want to specify the constants, you need to add ll :
    --- Quote End ---
    Hi stefaan
    i think i am missing something here. i will check this with nios2 sdk 5.1.
    i was actually referring to the nios2 gnupro sources (version 6.0). There, "nios2.md" does not include no "movdi" pattern for handling the DItype. Thus, the compiler can&#39;t know how to emit split 64-bit moves.
    what is the version/tool you have checked the load immediate constant for a (64-bit) long long?
    kind regards
    -kavi
    It was definatly not on the 6.0 yet. But you had a point here, because I was planning to port my application to nios2 6.0. I will check before I begin Thanks.
