21 years agoLong Boot Time after update to 5.0
after updating to Quartus / NIOS II 5.0 my design needs about 7 seconds to boot (reboot) from EPCS. With an oscilloscope I've measured, that the FPGA configuration is done in 80 msec. After a sho...
21 years agoHi Jesse & tns1,
First, I thank you both for your attention on this :-) > Do you mean Nios II 5.0 SP1? (Just released)? SP 1.04 -- this is SP1 plus the latest "list path" patch. > The fix is in the EPCS peripheral, relevant flash programming files, and all example designs I've been testing with the 1c20 example design. All I did was change the reset address and regenerate ... but no good. > I would reccomend opening your design in SOPC Builder, deleting and then > re-adding the EPCS peripheral, and re-generate/re-compile in quartus. Ok ... done, but ... > This should clear everything up. ... nope ... just as slow. tns1 mentioned: > In Quartus5.0SP1, the lines 'extradelay = 1;' are still present in class.ptf and > em_epcs.pm on lines 84, and 344 respectively. Are we back to the drawing board on this one ... time to try to old fix? Thanks --Scott
