21 years agoLong Boot Time after update to 5.0
after updating to Quartus / NIOS II 5.0 my design needs about 7 seconds to boot (reboot) from EPCS. With an oscilloscope I've measured, that the FPGA configuration is done in 80 msec. After a sho...
21 years agoHi Jesse,
Thanks for this great help. When changing extradelay to 0 all EPCS-Accesses now work as expected. But it was not easy to change this value. Changing in 'em_epcs.pm ' didn't also change the value in its corresponding class.ptf and so didn't change it in the ptf file of the CPU. I couldn't get class.ptf updated when reopening SOPC builder and adding an epcs-component. So I've changed it in 'em_epcs.pm' and also in its 'class.ptf' to get it accepted. In the corresponding custom board design is the asmi-component, also setting its extradelay. Changing this parameter also to zero, shortens Flash-Programmers time remarkable. But these parameters also were set in version 4.2 / NIOS 1.1 and worked correctly (fast). Why? Mike
