21 years agoLogon using UART
Hi, I am using the Altera Cyclone 1C20 board. When I configure the kernel use th UART as console I get the following kernel print out but I do not get the logon prompt. Linux echos ...
21 years agoThis is briefly mentioned in the reference guide under "Using a Nios Serial UART instead of the JTAG UART"
There are 2 parts to getting this to work: 1) changing the kernel console to the serial port (which you appear to have done successfully) and 2) change your inittab file to start a user console on the serial port To complete the second part of the process, do the following: a) In your filesystem project open the target/etc/inittab file b) remove the "# " from the line "# ttyS0:vt100:/bin/agetty 115200 ttyS0" c) save the inittab file d) rebuild your filesystem project e) upload your new romfs.bin to your board At this point both your kernel messages and your normal login should appear on the serial port. Dennis Scott Microtronix Datacom Ltd.
