20 years agoLog in problem
Hi, I've just installed uClinux v1.4 and I have followed the Linux Quick Start Guide with no luck. I am using Quartus v5.0 (Nios II 5.0) and my board is a Stratix Dev. Kit 1s10. I followe...
20 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- I used the following .sof file: C:\altera\kits\nios2\components\altera_nios_dev_board_stratix_1s10\system\altera_nios_dev_board_stratix_1s10.sof[/b] --- Quote End --- Hi gabi, you missed out http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif This is the sof you should use for µClinux: C:\altera\kits\nios2\examples\verilog\niosII_stratix_1s10\linux\linux_time_limited.sof <div class='quotetop'>QUOTE </div> --- Quote Start --- How can I check that Linux has actually booted?[/b] --- Quote End --- You'll see a shell invite begining withe a# or a login and password invite if you selected the agetty apps in the filesystem. Warm Regards
