17 years agoLocation of code that runs on Nios
Hi everyone, does anyone know where the code that runs on the nios is stored? I am wondering because I programmed my entire design into Flash about a week ago using the Flash Programmer in the...
17 years agoI don't think that the bootloader will check the system ID before running.
If you have written the software to flash, it will be automatically loaded when you reconfigure the FPGA. If you want to prevent this you need to disable the bootloader or erase the flash.
