17 years agoLocation of code that runs on Nios
Hi everyone, does anyone know where the code that runs on the nios is stored? I am wondering because I programmed my entire design into Flash about a week ago using the Flash Programmer in the...
17 years agoIf you use the System ID to verfify that there is no change it will only be recognised if you change something in the sopc. The programm runs in the memory device you have specified the moment you compiled your design. You can look that up in the System Library in the NiosII IDE.
