20 years agoLoading ucLinux on DE2
I am trying to load ucLinux on DE2. I compiled the kernel without ATA/ATAPI/MFM/RLL and networking support. But i could not find the option to set Link address offset for booting as specified in post.http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) <div class='quotetop'>QUOTE </div> --- Quote Start --- Processor type and features-->(0x00500000) Link address offset for booting[/b] --- Quote End --- I used Nios-II IDE to compile the kernel. I thought it would create problems only while booting the Kernel so proceeded with compilation. Kernel compiled succesfully. It created two files. vmlinux and vmlinux.bin. I thought vmlinux.bin is compressed version of vmlinux. vmlinux is 8.4MB and vmlinux.bin is 1MB. I used following command to download linux:
nios2_download -g vmlinux.bin and i get following error: ./vmlinux.bin File format not recognized. I tried using gzip on vmlinux and uploading vmlinux.gz there also i get the same error. One more problem is I am not sure if the kernel is being downloaded to flash or sdram. How can I specify that kernel should be loaded to sdram? should i do it in SOPC builder?1 Reply
mythri,
I load the De2 board with following commands. 1. Bin -> Flash bin2flash --input=vmlinux.bin --output=vmlinux.flash --location=0x0 2. Erase Flash nios2-flash-programmer --debug --erase=0x0+0x200000 --base=0x2000000 3. Load Linux nios2-flash-programmer --base=0x2000000 --debug vmlinux.flash The Reset Address needs to be specified in SOPC builder The base Address depends on your settings in SOPC builder
