12 years agoLoading NIOS from SRAM Arria V GX Starter
I am trying to configue NIOS to load from SRAM on the Arria V GX Starter kit. I have set up the system in Qsys and have attached the data master and instruction master to the tri-state controller tha...
12 years ago --- Quote Start --- Update. I got the DDR3 working (meaning that I'm able to write to and read from it correctly in NIOS), but I still cannot download an .ELF file to it. I get an error stating "Download ELF Process Failed". Verify failed at address 0x0200_0000 which is the base address of the DDR3 in my system. Please help! --- Quote End --- Hi I have a similar problem with DDR3. How do you connect the uniphy to your bus (clocks, bridges etc etc) ? Can you help me to at least read\write the DDR3 (as possible with a step by step tutorial :) I'm new of qsys\NIOS system). Thanks :)
