14 years agoLoading image to SDRAM under ubuntu
Hi, I am trying to run uclinux on DE0-Nano, and i successfully generated the zImage, but iam unable to load the image into SDRAM, it showing error like alex@alex:~$ nios2-download -g ~/...
14 years agoHelo sir,
1)While rebootinng my os its showing the error an error occured while mounting /proc/bus/usb press s to skip or m for manual recovery. 2.alex@alex:/$ jtagconfig 1) usb-blaster [7-1]020f30dd ep3c25/ep4ce22 2)alex@alex:/$ killall jtagd jtagd(1154): operation not permitted
jtagd: no process found 3)alex@alex:/$ nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage there are no nios ii cpus with debug modules available which match the values
specified. please check that your pld is correctly configured, downloading a
new sof file if necessary.
and another error is /opt/quartus/linux/libstdc++.s0.6: version 'glibcxx_3.4.11' not found (required by /user/lib/i386-linux-gnu/libproxy.so.1) showing when i tried to open quartus
Where is the mistake ? kindly any help? Thanks, Alex. (http://www.alteraforum.com/forum/editpost.php?do=editpost&p=154758)
