Loading data into memory
I'd like to load the SDRAM on my board (a DE2 board) with a specific file on my PC. As far as I can see there's no tool supplied that can accomplish this simply (I could probably mess around with linker scripts or some such thing but I'd prefer a simpler method). I tried using the JTAG uart however it's rather slow I wrote a small C program to run on the Nios II that just reads characters from it and then on my PC piped a file into the NiosII-Terminal program which works but it'll take several minutes to upload 1mb and I'd prefer something faster if possible.
So my question is, given a file on my PC can I add this into the build somehow so it gets loaded into SDRAM (or indeed another memory area) or perform such a task after the build? If not how I can I write to the JTAG UART faster (I get the feeling the NiosII-Terminal program is responsible for the slow transmission)?5 Replies
maybe ethernet with LwIP-Standalone (TFTP) or ethernet with uClinux is an option for you.
The emphasis here is on simple, so I'd don't want to use ethernet or uClinux.
Why not read the file into your C code as a char array? There's a Perl script (that can be easily modified) shipped with the standalone version of LWIP that can do this for you.
Also, you could use the FS2 console (nios2-console, n2c) to upload data to memory. EDIT: one more thing... if you can tolerate always using Debug mode, then the host filing system is hands-down the easiest method. See the included software template/example for reference. Cheers, - slacker - Altera_Forum
The host filing system seems to be a little slow (faster than the JTAG UART but still not quite the speed I wanted). The FS2 console works nicely though, thanks. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
--- Quote Start --- originally posted by gregac@Feb 6 2007, 12:15 PM i'd like to load the sdram on my board (a de2 board) with a specific file on my pc. as far as i can see there's no tool supplied that can accomplish this simply (i could probably mess around with linker scripts or some such thing but i'd prefer a simpler method). i tried using the jtag uart however it's rather slow i wrote a small c program to run on the nios ii that just reads characters from it and then on my pc piped a file into the niosii-terminal program which works but it'll take several minutes to upload 1mb and i'd prefer something faster if possible.so my question is, given a file on my pc can i add this into the build somehow so it gets loaded into sdram (or indeed another memory area) or perform such a task after the build? if not how i can i write to the jtag uart faster (i get the feeling the niosii-terminal program is responsible for the slow transmission)?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21289)
--- quote end ---
--- Quote End --- Dear GregAC, I am very new to niosII & DE2... I really need ur project which downloads file from PC to SDRAM. Can you please send it to me [email protected] Thanks in advance regards, Aditya
