21 years agoLoading a Filesystem onto the uKit?
Greetings,
My apologies for what is probably a simple question, but I am new to uClinux and uKit development. I've been going through the "Microtronix Nios II Linux Distrubution Quick Start Guide" and I have successfully compiled a new kernel and uploaded to the uKit device. I've also created a filesystem and an application. I would now like to upload the filesystem and mount it in Linux. Unfortunately the procedure specified in the document (right-click on romfs.bin and select upload) is not working for the following reason: ------------------------------------------------ Microtronix Linux Extensions Version 1.4, Built June 20, 2005 ------------------------------------------------ Expected integer value for option 'base' Value was: '' Using default value: -1 Aug 5, 2005 2:13:56 PM - (SEVERE) nios2-flash-programmer: No flash base specifie d I had this problem before when uploading the kernel, but I was able to set up the HW configuration (under the Run -> run menu) and get it to work. I can't seem to do the same thing here. I've looked through the "Microtronix Nios II Linux Distribution Reference Guide", but I don't see how to upload the filesystem along with the kernel, or just how to upload the filesystem. In addition, I'm assuming I need to mount the filesystem following the upload, but I'm not sure exactly how to do that. For reference, I have the Microtronix uKit with 16 MB SDRAM. I'm really not trying to do anything specific at the moment, just upload and link a filesystem (located in the SDRAM) to the linux kernel that I've already generated. If anyone can help or point me to additional documentation, I'd appreciate it. Thanks!1 Reply
Problem solved.
It turned out to be an installation problem. One of two things happened: 1> There was a corrupt file in the Quartus installation package OR 2> I installed the contents of the Microtronix uKit installation CD before installing the contents of nios2linux-1.4.zip. Once everything was installed properly, it worked as specified in the documentation.
