22 years agoloadable modules
does the nios II uClinux port support loadable modules? Adrian
22 years agoHi adac,
The NiosII Linux distribution does support loadable modules. We use the insmod et al in busybox. The busybox application that is pre-built in the distribution does not have those applets enabled so you would need to re-build busybox. Unfortunately, due to an oversight, the busybox source code did not make v1.0. So, the options are: 1) i can re-build busybox for you with this support and pass you the executable 2) i can zip up the busybox source and pass that to you 3) v1.1 of the distribution will be released July 9th -- busybox source will be present mike
