16 years agoload kernel linux in 2C35 board
load kernel linux in board 2c35
Hello, i have a problem to load kernal of µclinux in board 2C35, you have any solution to do this,using commande linux of host pc or quartus or nios2eds ? i followed the step of this link http://nioswiki.com/operatingsystems...uartusforlinux (http://nioswiki.com/operatingsystems/uclinux/quartusforlinux) but when i tape jtagconfig the message appeare [NiosII EDS]$ jtagconfigbash: jtagconfig : commande not found /opt if you have any suggestion for this
@Daixiwen, If you were referring to my problem, here is my response.
There are no errors when I run nios2-configure-sof. The .sof files in flash and RAM are almost identical. From a software interface standpoint, they would be the same as nothing changed in SOPC builder, just a few GPIO pins were re-routed. Right now, the problem has not resurfaced, so I'm going to let it go for the moment since I can't gather more relevant data. - Altera_Forum
hello,
for my situation i configure the FPGA with .sof, there are two .sof one with VHDL other with verilog i use the last with verilog but do you think this .sof work good,because i try to compile it with quatus give many erros? error: Tcl Script File NiosII_cycloneII_2c35_full_featured_sopc.qip not found Info: set_global_assignment -name QIP_FILE NiosII_cycloneII_2c35_full_featured_sopc.qip error: Tcl Script File ddr_sdram_0.qip not found Info: set_global_assignment -name QIP_FILE ddr_sdram_0.qip - Altera_Forum
You may have to generate the sopc system first. Open SOPC Builder and click "generate"
