16 years agoload kernel linux in 2C35 board
load kernel linux in board 2c35 Hello, i have a problem to load kernal of µclinux in board 2C35, you have any solution to do this,using commande linux of host pc or quartus or nios2eds ? ...
16 years ago@Daixiwen, If you were referring to my problem, here is my response.
There are no errors when I run nios2-configure-sof. The .sof files in flash and RAM are almost identical. From a software interface standpoint, they would be the same as nothing changed in SOPC builder, just a few GPIO pins were re-routed. Right now, the problem has not resurfaced, so I'm going to let it go for the moment since I can't gather more relevant data.
