16 years agoload kernel linux in 2C35 board
load kernel linux in board 2c35 Hello, i have a problem to load kernal of µclinux in board 2C35, you have any solution to do this,using commande linux of host pc or quartus or nios2eds ? ...
16 years agoAre you sure it is the exact same .sof file in both cases? I fail to see why the CPU wouldn't respond when you try to access it from the linux machine.
When you run nios2-configure-sof on the silux machine, are you sure everything goes well? No error?
