16 years agoload kernel linux in 2C35 board
load kernel linux in board 2c35 Hello, i have a problem to load kernal of µclinux in board 2C35, you have any solution to do this,using commande linux of host pc or quartus or nios2eds ? ...
16 years agoThe .sof file is in the flash. However, even when I try to download it using 'nios2-configure-sof', I still have trouble running with the 'nios2-download'.
I was able to briefly regain good performance after running this same sequence on the Windows partition. Eventually, it started failing on the Linux side with this same error.
