16 years agoload kernel linux in 2C35 board
load kernel linux in board 2c35 Hello, i have a problem to load kernal of µclinux in board 2C35, you have any solution to do this,using commande linux of host pc or quartus or nios2eds ? ...
16 years agohello,
thank's for advices i add the /opt/altera9.1sp1/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin)to the PATH when i execute the commande [NiosII EDS]$ nios2-download -g /opt/altera9.1sp1/nios2-linux/uClinux-dist/images/zImage the message appear: Using cable "USB-Blaster [USB 7-1.2]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused for the value of variable: QUARTUS_ROOTDIR=/opt/altera9.1sp1/quartus $SOPC_KIT_NIOS2 =/opt/altera9.1sp1/nios2eds but there are anthing in variable LD_LIBRARY_PATH ?
