13 years agoLoad custom-data to On-Chip memory
Folks, what would be the best way to load custom data to the on-chip memory of a Cyclone IV FPGA, preferably at start up. Eventually a NIOS II application reads data from a flash device and sto...
13 years agoMy recommendations:
1) Static data - If you plan on pre-initalizing the memory so that it is ready to go after the device is configured then I would use the Qsys on-chip RAM component and make sure the memory initialization feature is on. I typically change the initialization file name from the default when I parameterize the on-chip memory component. Unfortunately that component doesn't support the .mif file format which is much easier to work with using text editors or spreadsheets (if you generate data in a spreadsheet for example) but Quartus can convert between the file formats if I remember correctly. Either way, Quartus has an initialization editor that you can use which provides a graphical interface to type in values or copy and paste. 2) Dynamic data - If you want to re-use the same hardware and change the contents of the memory (much faster than recompiling the hardware with new contents) they you can use the same on-chip memory component in Qsys and just update it dynamically. You can enable the in-system memory editor feature of the on-chip RAM and use the in-system memory editor tool to update the RAM contents dynamically. Alternatively you could connect the JTAG to Avalon bridge to this memory and use System Console to repopulate the RAM with new contents. So there are many ways to accomplish memory initialization. If you pick a method we can give you more advice on how to use it. I personally think the dynamic updating would be a better approach since you plan on having Nios II updating the memory as an end goal.
