15 years agoload and write image under nios
hello i have a code in c++ how use image in studio vusial I give the path of image and I have the result I turn the some code inder nios but the when I give the path of image the niosIde not fo...
15 years agohello
I have an algorithm in C++ how turn correctly under visual C++ I want to implement in softwere . and I use Nios II Ide the problem the processor NiosII can't use the image if sameone know the commade or prossesus in order to the nios can exploit the image thank you
