15 years agoload and write image under nios
hello i have a code in c++ how use image in studio vusial I give the path of image and I have the result I turn the some code inder nios but the when I give the path of image the niosIde not fo...
15 years agoWhere is the file supposed to be stored?
Do you have a filesystem on your Nios board? Or do you want to store the raw image data on a flash eprom? Or maybe you want Nios to access data on your computer hard disk? In this case you need a server program on pc which communicates with a client running on Nios client. I'm not sure, but I believe there's a reference design to make this, using jtag uart as the link channel: try search the forum or Altera website for it.
