20 years agolinux/cygwin build difference
Hi, guys, I'm trying to build a new kernel for my Nios II Dev board with PCI support. I am using the patch from Microtronix and here comes the problem. I was able to compile a kernel w...
20 years agoIt's not a customized board and I didn't have error during the patches.
I asked Microtronix and received a packet with their own cross compiler (not free!!). I simply changed my PATH to their compiler. It's compiled well and worked! I'd bet they tweak their compiler for the board somehow. Unfortnately no source code sent to me. I'll try to diff the toolchain when I pass this project. Thanks for all the help! --- Quote Start --- originally posted by hippo@Mar 16 2006, 10:51 PM did you get error message when applying the patches?
or you can try out altera pci core, which is supported in the new kernel.
check post#52 in the buildroot guide.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13536)
--- quote end ---
--- Quote End ---
