20 years agolinux/cygwin build difference
Hi, guys, I'm trying to build a new kernel for my Nios II Dev board with PCI support. I am using the patch from Microtronix and here comes the problem. I was able to compile a kernel w...
20 years agoIs it a custom board? As a general rule, just because one piece of software works, doesn't mean your hardware is good... when I design custom hardware, I subject it to extensive hardware tests beforehand to make sure it's functional.
I agree that it's unlikely to be hardware, but any custom hardware should be thoroughly tested before loading something like linux on it. I can't tell you how many times I have pulled my non-existant hair out because software wasn't working, and it was a hardware issue. I don't know if this is it or not, but once, I got weird results building on my linux machine when I Was running a 64-bit kernel - because gcc wasn't setup correctly. Just thought I would mention that. Other than that, the other linux gurus can help you out more... sorry http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
