20 years agolinux/cygwin build difference
Hi, guys, I'm trying to build a new kernel for my Nios II Dev board with PCI support. I am using the patch from Microtronix and here comes the problem. I was able to compile a kernel w...
20 years agoBut I ftped the kernel binary file from Microtronix and tested on the same board and it's working fine. They claimed it's built on cygwin/IDE 5.1.
I wish I could build from toolchain and eventually add my part of modules. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif --- Quote Start --- originally posted by jdhar@Mar 16 2006, 03:26 PM it really does seem like a hardware issue... especially if you have tried a minimum build and it still does it. have you tried running out of flash maybe to see if it still happens?<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13519)
--- quote end ---
--- Quote End ---
