20 years agolinux/cygwin build difference
Hi, guys, I'm trying to build a new kernel for my Nios II Dev board with PCI support. I am using the patch from Microtronix and here comes the problem. I was able to compile a kernel w...
20 years agoI would suggest sticking with the linux build tree.. once you get it working, it will be well worth it. However, regarding your problem... it does seem odd. Have you ruled out hardware as being faulty? Try compiling in initramfs in the linux build and paste your boot output... your problem is rather odd.
