17 years agoLinux with MMU on NEEK
Hi, all. I'm testing Linux MMU version, on my NEEK. http://www.nioswiki.com/linux It works fine and I can use "bash" shell. This is the evident proof that we are using the true 'fo...
16 years ago --- Quote Start --- Hi, The Linux with MMU for Nios2 distribution is still under construction, and you must solve many problems by yourself. Frankly speaking, I think it is a little bit hard to rebuild the kernel for linux and Nios beginners. Kazu --- Quote End --- I am now confused with your answer compared to nioswiki, and what things unresolved to have a full-running Linux (uClinux + MMU) in Nios2 distribution?
