17 years agoLinux with MMU on NEEK
Hi, all. I'm testing Linux MMU version, on my NEEK. http://www.nioswiki.com/linux It works fine and I can use "bash" shell. This is the evident proof that we are using the true 'fo...
16 years ago --- Quote Start --- But please note that the cache size is limited within 4KB. In present codes, there is no mechanism to avoid the alias problem. --- Quote End --- So it is not correctly implemented. All Altera example designs use much more cache ! What should we do about that ? I feel that 4K cache will degrade performance a lot.. I did not test this thoroughly, but I once did a speed test with a uCLinux vs a fill lunux design and found that the full Linux design was much slower (up to half speed). I'm not sure about the cache sizes, though . -Michael
