17 years agoLinux with MMU on NEEK
Hi, all. I'm testing Linux MMU version, on my NEEK. http://www.nioswiki.com/linux It works fine and I can use "bash" shell. This is the evident proof that we are using the true 'fo...
16 years agoHi,
--- Quote Start --- As mentioned earlier in the thread, I've done this, and it runs, but ethernet does not work. --- Quote End --- The thing is not so easy, because the kernel code itself does not use MMU's address conversion mechanism. So we need an adequate user-land program to stick the pinhole. Kazu
