17 years agoLinux with MMU on NEEK
Hi, all. I'm testing Linux MMU version, on my NEEK. http://www.nioswiki.com/linux It works fine and I can use "bash" shell. This is the evident proof that we are using the true 'fo...
16 years agoHi,
--- Quote Start --- Are those really used somewhere ????? --- Quote End --- 'IO_BASE' is not used anywhere, but 'UNCAC_BASE' had been used before. Please see# 4 and# 5 of this thread. About the clearance of these confusion, I think it's not so difficult but not so easy... (The most difficult thing is 'who will do it?'.:D) --- Quote Start --- So: do you suggest that you are hit by a compiler, linker, or system setup bug here ? --- Quote End --- I think this is caused by the incomplete implementation of Nios's linker. Kazu
