17 years agoLinux with MMU on NEEK
Hi, all. I'm testing Linux MMU version, on my NEEK. http://www.nioswiki.com/linux It works fine and I can use "bash" shell. This is the evident proof that we are using the true 'fo...
16 years ago --- Quote Start --- Yes, 'call 0x2000870' is only a mischief of the debugger. The real memory contents are '0008ac40', i.e. 'call 0x870'. --- Quote End --- ... which seems to be quite correct to me on the first view. So: do you suggest that you are hit by a compiler, linker, or system setup bug here ? -Michael
