17 years agoLinux with MMU on NEEK
Hi, all. I'm testing Linux MMU version, on my NEEK. http://www.nioswiki.com/linux It works fine and I can use "bash" shell. This is the evident proof that we are using the true 'fo...
16 years ago --- Quote Start --- Hi, Please see and try this. Kazu P.S. Why can't we attach *.c and *.h files directly? --- Quote End --- Thanks a lot! The driver seems to work at some level now. dhcpcd doesn't work, with either driver I get:
dhcpcd: terminating on signal 7 and it takes down eth0 if it was previously brought up with ifconfig. It's a SIGBUS so probably another incorrect memory access issue.
