17 years agoLinux with MMU on DE2-70
Having followed the instructions, modified some defines in nios2.h and enabled the networking support, finally got linux image for my DE2-70. Unfortunately, the kernel boot get stuck:
Linux/Nios II-MMU init_bootmem_node(?,0x4476, 0x4000, 0x6000) free_bootmem(0x4476000, 0x1b8a000) reserve_bootmem(0x4476000, 0x400) Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128 Kernel command line: NR_IRQS:32 PID hash table entries: 128 (order: 7, 512 bytes) Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) We have 24576 pages of RAM Memory available: 27908k/4566k RAM, 0k/0k ROM (1450k kernel code, 3115k data) Calibrating delay loop... 49.25 BogoMIPS (lpj=246272) Mount-cache hash table entries: 512 net_namespace: 296 bytes NET: Registered protocol family 16 init_BSP(): registering device resources bio: create slab <bio-0> at 0 NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 1024 (order: 1, 8192 bytes) TCP bind hash table entries: 1024 (order: 0, 4096 bytes) TCP: Hash tables configured (established 1024 bind 1024) TCP reno registered NET: Registered protocol family 1 Any ideas what else should be done to make it work?5 Replies
my linux image is just the same with yours.you mean it cannot work yet?
go back to "Creating a Nios II Design with an MMU" page.if you assigned the s1 and s2 with different addresses, try a same address.
or you can select auto-assign base addresses in SOPC Builder for why. good luck. - Altera_Forum
I have done this ,I didn't make the web server work for now .I want to know that did you succeed in doing this?
my problem is just the same with chonger's at that time, so I found here but there was no answer.
after that, I try auto-assign in SOPC Builder and found they have same address by default. so I modified and figured it out. maybe we have the different reason. sorry that can't help you. - Altera_Forum
Thank you eric.L, auto assign address fixed the problem. :)
