20 years agolinux on DE2
I try to run linux on DE2,when download vmlinux.bin into ram,it happen :
Linux version 2.6.11-uc0 (ty@ty024) (gcc version 3.4.1 (Altera Nios II 5.1 b73)) # 2 Thu Apr 27 20:24:19 2006 on .4.1 (AlteNios II I 5.1 b73))# 2 Thpport © 2004 Microtronix Datacom Ltd. s ilt 1 zonelists I support ©d line: root=/dev/mtdblock0 ro BuD hash table entries: 64 (order: 6, 1024 bytes) tdblock0 ro PIsh table entries: 2048 (order: 1, 8192 bytes) Dentry cache hatable entries: 1024 (order: 0, 4096 bytes) ) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) 288k data) ble: 6372k/8192k RAM, 0k/0k ROM (1412k kernel code, 288k data) Registered protocol family 16 512 (order: 0, 4096 bytes) NET: Registered protocol family 16 000ial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x81004cheduler anticipatory registered scheduler noop registered io sededuler anticipatory registered io scheduler deadline registered io scheduler cfq registered ksize driver initialized: 16 RAM disks of 4096K size 1024 blocksize tera NDK flash (AMD): Found 1 x16 devices at 0x0 in 8-bit bankps: 1 Fujitsu Extended Query Table at 0x0040 number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-susing not available code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Usin"Altera NDK flash (AMD)": nition Creating 4 MTD partitions on "Altera NDK flash (AMD)": s2" extends beyond the end of device "Altera NDK flash (AMD)" -- size truncated to 0x200000 device "Altera NDK flash (AMD)" --nel" truncated to 0x200000 0x00000000-0x00200000 : "loader/kernel" er configuration" is out of reach -- disabled td: partition "User configuration" is out of reach -- disabled fe configuration" is out of reach -- disabled td: partition "safe configuration" is out of reach -- disabled NET: Registered protocol family 2 ished hash table entries: 512 (order: 0, 4096 bytes) TCP establash table entries: 512 (order: -1, 2048 bytes) tes) TCP bind h configured (established 512 bind 512) bytes) TCP: Hash tables family 1 (established 512 bind 512) NET: Registered protocol family 1 NET: Registered protocol family 17 ios II 5.1 b73))# 2 Thu Apr 27 20:24:19 2006 on .4.1 (AlteNios II I 5.1 b73))# 2 Thpport © 2004 Microtronix Datacom Ltd. suilt 1 zonelists I support © line: root=/dev/mtdblock0 ro BID hash table entries: 128 (order: 7, 2048 bytes) dblock0 ro Phash table entries: 4096 (order: 2, 16384 bytes) Dentry cache sh table entries: 2048 (order: 1, 8192 bytes) ) Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) 288k data) ble: 6360k/8192k RAM, 0k/0k ROM (1412k kernel code, 288k data) el panic - not syncing: Can't create rootfs , 4096 bytes) Kernel panic - not syncing: Can't create rootfs It may need filesystems,i want to know how and where i should download the filesystems into ram? thank you!!1 Reply
The file system should be loaded at address 0x200000.
You can adjust partitions in the file altera.c
