15 years agoLinux kernel, stdm++ error
Hi,I follow the "linux quick start" document to build the kernel, but have errors as follow:
------------------------------------------------------------------------------------------------ stdm++.cxx:1:18: error: stdm++: No such file or directory stdm++.cxx:4: error: 'MATT' has not been declared stdm++.cxx:4: error: expected constructor, destructor, or type conversion before '(' token stdm++.cxx:21: error: 'MATT' has not been declared stdm++.cxx:21: error: expected constructor, destructor, or type conversion before '::' token stdm++.cxx:34: error: 'MATT' has not been declared stdm++.cxx:34: error: 'int operator<<(char*)' must have an argument of class or enumerated type stdm++.cxx:34: error: 'int operator<<(char*)' must take exactly two arguments stdm++.cxx: In function 'int operator<<(char*)': stdm++.cxx:36: error: invalid use of 'this' in non-member function stdm++.cxx:36: error: 'fprintf' was not declared in this scope stdm++.cxx: At global scope: stdm++.cxx:41: error: 'MATT' has not been declared stdm++.cxx:41: error: expected constructor, destructor, or type conversion before 'MATT' ------------------------------------------------------------------------------------------------ I found some session about this problem: ------------------------------------------------------------------------------- There are some pieces missing from the test c++ apps. Find attached a patch........ ---------------------------------------------------------------------------------------------------- Which patch would fix the error?No RepliesBe the first to reply
