20 years agoLinux driver for USB ISP1161 not working
I have been trying to get the USB HCD driver for the Philips ISP1161 host controller which is on the Microtronix USB-Ethernet board working. According to the wiki, it is supported and should work. ...
20 years agoThe ISP116x driver shipped with the kernel works OK for me (tested with 2.6.15, 2.6.16 and 2.6.17). arch/nios2nommu/kernel/usb.c needs patching though:
Index: arch/nios2nommu/kernel/usb.c =================================================================== --- arch/nios2nommu/kernel/usb.c (revision 92) +++ arch/nios2nommu/kernel/usb.c (revision 93) @@ -26,6 +26,7 @@ # include <linux/init.h> # include <linux/device.h> # include <linux/delay.h> +#include <linux/platform_device.h> # include <asm/io.h> # include <asm/irq.h> @@ -139,27 +140,14 @@ static struct isp116x_platform_data isp116x_data = { // Enable internal resistors on downstream ports .sel15Kres = 0, - // Clock cannot be stopped - .clknotstop = 1, // On-chip overcurrent protection .oc_enable = 0, // INT output polarity .int_act_high = 0, // INT edge or level triggered .int_edge_triggered = 0, - // End-of-transfer input polarity - .eot_act_high = 0, - // DREQ output polarity - .dreq_act_high = 1, - // WAKEUP pin connected - .remote_wakeup_connected= 0, // Wakeup by devices on usb bus enabled .remote_wakeup_enable = 0, - // Switch or not to switch (keep always powered) - .no_power_switching = 1, - // Ganged port power switching (0) or individual port power switching (1) - .power_switching_mode = 0, - .reset = NULL /* isp116x_reset */, .delay = isp116x_delay, }; The problem with the kernel halting is because an active HIGH level-triggered interrupt is expected, and the 116x default has an active LOW interrupt line (at least it was for me). I tried programming the interrupt polarity in the driver, but that did not help, so I ended up inverting the IRQ signal in my FPGA Image. - Atle
