13 years agoLinux-Driver for Altera PCIe HIP or simple methode to access PCIe
Hi everyone! I know it's an old problem, but I don't see it solved yet. I' currently working on a FPGA-Design on the Arria II GX Development Kit. I made a I2C-Core which I now have to feed wi...
13 years agoNow I have a little speed problem:
I made a design in qsys where a 32bit fifo is connected to the avalon bus on both sides (in and out). It has a depth of 8192. With a litte addidion I used the pci_debug - program to messure the time for write and read operations with the following code:
errorcounter=0;
writedata = 0x00000010;
clock_gettime(CLOCK_REALTIME, &start);
for (i=0; i<8190; i++)
*(volatile unsigned int *)(dev->addr + 0x09400000) = (writedata * i);
clock_gettime(CLOCK_REALTIME, &end);
clock1 = (unsigned long)(end.tv_nsec - start.tv_nsec);
clock1sec = (unsigned long)(end.tv_sec - start.tv_sec);
readdata = 0x00000010;
readdata =*(volatile unsigned int *)(dev->addr + 0x09400040);
clock2 = (unsigned long)(end.tv_nsec - start.tv_nsec);
clock2sec = (unsigned long)(end.tv_sec - start.tv_sec);
printf("Summary 32Bit Fifo:\n");
printf("8190 Cells written in %.2ld s and %.9ld ns.\n", clock1sec, clock1);
printf("8190 Cells read in %.2ld s and %.9ld ns.\n", clock2sec, clock2);
To my surprise the 8190 writes took 792 us (that makes about 41MB/s) and the reades took 11869 us (that makes about 2.8 MB/s). Why is it so slow? To my design: I used the "QSYS PCIe to ext memory" reference design and reduced it to PCIe 1x and the clock sources. Then I added the fifo. The Design works but it seems that it is slow as hell. Is there something I've done wrong or how else can I speed up the design? https://www.alteraforum.com/forum/attachment.php?attachmentid=6816 I want to use a schematic file for my top-level design-file so I tried to translate the original file to a BDF-File: https://www.alteraforum.com/forum/attachment.php?attachmentid=6817 Have I forgotten something?
