21 years agoLinux development environment
Does anyone know if the Nios II port of uClinux is available as a simple tarball (i.e. tar.gz or .tgz) that can be downloaded to a Linux machine and configured and built using the nios2-elf-gcc cross...
21 years agoNow it sounds more like the procedure you created the elf file. Can you tell me how you made cpuload.elf? Which linker script are you using?
Regards, wentao microtronix
