21 years agoLinux development environment
Does anyone know if the Nios II port of uClinux is available as a simple tarball (i.e. tar.gz or .tgz) that can be downloaded to a Linux machine and configured and built using the nios2-elf-gcc cross...
21 years agoI successfully compiled the elf2flt utility under Linux.
Now I am having a problem using the elf2flt utility. I have the same problem under my Cygwin environment under Windows. If I use nios2-elf-gcc to compile a simple program (e.g. nios2-elf-gcc hello.c -o hello) and try to use the elf2flt utility to convert the format to flat, it gives me the following error: hello: Input file contains no relocation info The hello file is the executable that was created directly from the nios2-elf-gcc compiler. If I try to run the hello file directly on my uKit Nios II development board, then I get the format errors described a couple replies back. WHAT AM I MISSING HERE?
