21 years agoLinux development environment
Does anyone know if the Nios II port of uClinux is available as a simple tarball (i.e. tar.gz or .tgz) that can be downloaded to a Linux machine and configured and built using the nios2-elf-gcc cross...
21 years agoThanks again for your help. I will untar a pristine tarball and try the process over.
I have assumed that for the newlib portion in step 4, you meant to have "../newlib/configure" instead of "../make/configure". Is this correct, or is this why I'm having problems?
