15 years agoLinux Boot on the custom board. (Exception:init process)
Hi everyone!
I have trying to run Linux on my custom board. But, Linux startup, an exception occurs.
kernel_init()
init_post()
run_init_process() ※Exception Root file system mounted. And then, An exception occurred at start the "/init"process. I've already replaced custom_fpga.h. Do you think there are anything of what I have to do ? Thanks a lot All. ※This topic has moved from [The problem with custom board. (Exception access user space)]. http://www.alteraforum.com/forum/showthread.php?t=262031 Reply
Hi everyone!
Solved this problem. Linux has started successfully. I changed EXCEPTION_ADDR from 0xC0000040 to 0xC0000020. This is referred to the design NEEK. Thank you for help.
